Discussion: Dreambox 7025+
Mode arborescent
  1. #15
    Membre Avatar de toysoft
    septembre 2012
    Il n'y a pas de Sim dans le DM7025+, donc vaut mieux peut être ne rien dire quand on ne connait pas le matos que l'on critique (cf DM7025+) pour proposer autre chose... le DM7025+ est une superbe machine et elle a encore pas mal d'avenir devant elle...
    Voir les specs ici :
    Code:
    https://dreambox.de/en/dm7025
    TS
    Powerful receiver for digital TV and Radio programs..
    Main features are a 300 MHz processor; the dreambox DM7025+ supports the Linux TV API
    • 10/100MBit compatible Ethernet Interface
    • Twin-Tuner DVB-S, DVB-C or DVB-T
    • plug & play, mixable
    • big size OLED display
    Technical Features
    • 300 MHz MIPS Processor
    • Enigma 2, Linux Operating System
    • big-size OLED - Display
    • MPEG-2 Hardware decoding, DVB-S
    • TWIN Tuner, mixable, Plug&Play
    • Tuner: DVB-S, DVB-C und DVB-T, pluggable
    • 1 x DVB Common-Interface Slot
    • 2 x Smartcard-Reader (Dreamcrypt CA)
    • V.24/RS232 Interface
    • Integrated Compact Flash Slot
    • 10/100 MBit compatible Ethernet Interface
    • 1 x USB
    • S/PDIF Interface for digital bit stream out (AC-3)
    • 2 x Scart-interfaces
    • RF modulator
    • Audio/Video cinch out
    • 32 MByte Flash, 128 MByte RAM
    • integrated IDE Interface
    • Support for internal IDE HDD 3,5 inch in any capacity
    • unlimited channel lists for TV/Radio
    • channel-change time < 1 second
    • automatic service scan
    • directly bouquet-lists
    • EPG (electronic program guide)
    • Videotext Decoder
    • multiple LNB-Switching control (DiSEqC)
    • OSD in many languages and skin-support
    DreamBox DM7025+ technical data
    DBS-Tuner:
    Frequency Range 950 ... 2150 MHz
    Signal Level - 65 dBm ... - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Common-Interface:
    Common-Interface Power Consumption max. 0,3A/5V
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz, NTSC
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical (AC3)
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB, S-Video
    VCR-Scart:
    FBAS
    Serielle Interface RS 232:
    Typ RS232 bidirectional
    Bitrate 115,2 kBit/s max.
    Plug Connector SUB-D-9
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    USB:
    USB 1.1 connector
    UDMA100 IDE Interface:
    for internal HDD
    Compact Flash - Reader
    LNB power and polarisation per tuner:
    LNB Current 500mA max.; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    Count of active satellite position:
    DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
    Power consumption:
    < 30W (in operation, horizontal polarization / 400mA LNB current)
    < 25W (in operation, no LNB)
    < 10W (Deep-Standby-Mode)
    Input voltage:
    230V / 50 Hz alternating current +/- 15%
    110V / 60 Hz alternating current +/- 15%
    Physical specification:
    Ambient Temperature +15°C...+35°C
    Humidity < 80%
    Size (W x D x H): 374 mm x 230 mm x 75 mm
    Weight: 1,8 kg without HDD
    je ne sus pas vendeur, il me samble bien que vous vendez de SIM de DM dans le temp et vous ete reste avec la nostalgie du passe.
    Dernière modification par toysoft ; 01/09/2017 à 21h40.
