OpenPLi 4.0 IPTV avec GStreamer de dernière generation pour FTA IPTV de qualité
So here s whats up:
- Brand new bootlogo thanks to .:MarcinO:.
- OpenPLi enigma2 rev: 4bf2f1e45593065f9e2b4563f30463487b727c94
- OpenPLi oe-core rev: d76cfe6a39c6613ac77578840b214f0f1e748a39
- Taapat s Fulan enigma2 rev: 2a984c500f5b2ea657f68742b7dc4e47f5586483
- New receivers supported:
* osmini
* osminiplus
* spycat
* spycatmini
* et7000mini
* xpeed lx
* xpeed lx pro
- New feed server located in Europe thanks to the Japhar team!
- Japhar IPTV list
- No more use of UPX compression on ARM platform (should fix the Vu+ Solo 4K build)
- Latest gstreamer 1.9 revision from master branch
- FFmpeg 3.0.2 with extra options enabled (based on oe-e recipe)
- Kodi 16.1 for Vu+ Solo 2, Solo Se, Duo 2, and Solo 4K (thanks to mx3L for his bsp + recipes)
- More wifi drivers (mt7601, rt7777 etc..) taken from oe-alliance
- MX3L s serviceapp now supports EPG and embedded subtitles
- Exteplayer3
ServiceApp and exteplayer3:
Thanks for the hard work from mx3L and samsamsam you can now play your IPTV streams with exteplayer3 or gstplayer instead of the default dvbmediasink.
Especially using exteplayer3 will give much better performance on playing HLS streams compared to gstreamer + dvbmediasink.
For example, playing DJING underground 720p never worked very well on my DM800HD and now it does
In a nutshell here s how it works.
In your /etc/enigma2/ directory you have your channel bouquets with the .tv and .radio extensions.
Inside these files there s this for example:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
#DESCRIPTION DJING Underground (CDN)
By default this will play with the gstreamer dvbmediasink (which is currently broken for sh4).
If you like to play your stream with exteplayer3 instead you should change the 4097 to 5002, like this:
#SERVICE 5002:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
You can also change it to play with gstplayer using 5001:
#SERVICE 5001:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
So it s like this:
4097 = default player, which is the dvbmediasink if serviceapp is not enabled
5001 = gstplayer
5002 = exteplayer3
Now let s say you d like to convert your entire bouquet to play with exteplayer3, simply login to your receiver with telnet/ssh (use PuTTY for Windows).
And issue to the following commands:
First stop enigma2:
init 4
Then change your bouquet to make all streams play with exteplayer3, lets say userbouquet.favourites.tv:
cd /etc/enigma2
sed -i s/^#SERVICE 4097/#SERVICE 5002/g userbouquet.favourites.tv
Then restart enigma2:
init 3
That s it !
You can also make exteplayer3 the default backend for playing back everything.
Go to Menu -> Plugins -> ServiceApp and set exteplayer3 as default.
Keep in mind that with exteplayer3 or gstplayer as default backend you will not have support for external subtitles yet (.srt for example).
That s why I ve added MediaPlayer2 and SubsSupport from mx3L.
Please thank mx3L for the hard work he put into this
- AirDigital
Zgemma Star S, Zgemma Star 2S, Zgemma Star H1, Zgemma Star H2, Zgemma Star LC, Zgemma HS, Zgemma H2S, Zgemma H2H, Zgemma H5, Zgemma I55
Zgemma Star LC :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-lc_usb.zip
Star H1 / Star H2 / Star S / Star 2S / Zgemma Star H2 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-sh1_usb.zip
H.S. / H.2S / H.2H / Zgemma H.2H :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-h3_usb.zip
H5 / Zgemma H5 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-h5_usb.zip
I55 / Zgemma I55 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-i55_usb.zip
- Amiko
Alien 8900 / Alien2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-spark7162_usb.zip
Amiko Spark STI7111 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-spark_usb.zip
- Atemio
Atemio Nemesis :
Code PHP:
http://jam3.japhar.com/images/pli/atemionemesis_usb.zip
- Dreambox (Original)
DM500hdv2, DM800sev2, DM7020hd, DM7020hdv2
DM500HDv2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-dm500hdv2.nfi
DM800HDseV2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-dm800sev2.nfi
DM7020HD :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-dm7020hd.nfi
DM7020HDv2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-dm7020hdv2.nfi
- EDISION
Edision OS mini :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-osmini_usb.zip
Edision OS mini+ :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-osminiplus_usb.zip
- Formuler
F1 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-formuler1_usb.zip
F3 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-formuler3_usb.zip
F4 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-formuler4_usb.zip
- Galaxy Innovations :
ET7000 Mini :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et7000mini_usb.zip
- Golden Interstar
XPEED LX Class S2 :
Code PHP:
http://jam3.japhar.com/images/pli/xpeedlx_usb.zip
XPEED LX class S2/C :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-xpeedc_usb.zip
XPEED LX3 :
Code PHP:
http://jam3.japhar.com/images/pli/xpeedlx3_usb.zip
XPEED LX Pro :
Code PHP:
http://jam3.japhar.com/images/pli/xpeedlxpro_usb.zip
- HEROBOX
EX3 HD :
Code PHP:
http://jam3.japhar.com/images/pli/herobox_usb.zip
- MaxDigital
XP1000 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-xp1000_usb.zip
- MiracleBox
Mini :
Code PHP:
http://jam3.japhar.com/images/pli/mbmini_usb.zip
MiniPlus :
Code PHP:
http://jam3.japhar.com/images/pli/mbminiplus_usb.zip
Ultra :
Code PHP:
http://jam3.japhar.com/images/pli/mbultra_usb.zip
Xsolomini3 / Miraclebox Premium Mini Plus :
Code PHP:
http://jam3.japhar.com/images/pli/xsolomini3_usb.zip
- Mut@nt
HD500C :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd500c_usb.zip
HD1100 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd1100_usb.zip
HD1200 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd1200_usb.zip
HD1265 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd1265_usb.zip
HD2400 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd2400_usb.zip
HD1500 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-hd1500_usb.zip
- SpyCat
Spycat :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-spycat_usb.zip
Spycat mini :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-spycatmini_usb.zip
- VuPlus (Original)
VuSolo :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vusolo_usb.zip
VuDuo :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vuduo_usb.zip
VuUno :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vuuno_usb.zip
VuZero :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vuzero_usb.zip
VuUltimo :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vuultimo_usb.zip
VuSolo2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vusolo2_usb.zip
VuDuo2 :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vuduo2_usb.zip
VuSoloSe :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vusolose_usb.zip
VuSolo4K :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-vusolo4k_usb.zip
- Xtrend
ET4x00, ET5x00, ET6x00, ET7x00, ET8000, ET8500, ET9x00, ET10000
ET4x00 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et4x00_usb.zip
ET5x00 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et5x00_usb.zip
ET6x00 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et6x00_usb.zip
ET7x00 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et7x00_usb.zip
ET8000 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et8000_usb.zip
ET8500 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et8500_usb.zip
ET10000 :
Code PHP:
http://jam3.japhar.com/images/pli/OpenPLi-4-et10000_usb.zip
- XSarius Fusion
XSarius Fusion HD :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-fusionhd_usb.zip
XSarius Fusion HD SE :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-fusionhdse_usb.zip
XSarius Pure HD :
Code PHP:
http://jam3.japhar.com/images/pli/openpli-enigma2-4-purehd_usb.zip
- XSoloMini
Xsolomini3 :
Code PHP:
- Japhar v20
DM800HD+ :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=2294
DM500HD+ :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=1938
DM800HDse+ :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=1940
DM8000HD :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=1939
- Ferrari v20
VU+ Solo v3 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9004#Post9004
VU+ Solo v2 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9320
VU+ Duo v3 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9005#Post9005
VU+ Duo v2 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9326
VU+ Uno v3 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9006#Post9006
- Lonrisun v20
VU+ Solo2 v1 & v4.2 :
Code PHP:
http://www.ourdreambox.com/ubbthreads.php?ubb=showflat&Number=9007#Post9007
Bon amusement !
TS
