Va pour la qualité de réception "s2", celui que je prends a les spécificités suivantes
Dual-Core CPU, 396 MHz MIPS Processor
DDR III 256M ,ROM 400M,Serial Flash 8M
DVB S2 demodulator
Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
MPEG-2 MP@HL & MP@ML;MPEG-1 Layer I & II & III, Digital Audio(AC3);
SCPC & MCPC receivable from C/Ku band satellites;
multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
NIT search supported;
Support MPEG-5;
Support HDMI 1.3;
Support PVR(store in USB disk);
Multimedia files playback(by USB);
Support Electronic Program Guide(EPG) for 7 days;
Teletext and subtitle out through OSD;
Support multi-lingual DVB subtitle and teletext;
Automatic and manual channel scan options;
automatic service scan
channel-change time < 1 second
OSD in many languages and skin-support
Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish,
Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable
High light LED Display
Multiple display mode: 1080p/1080i/720p/570p/576i/480p;
MPEG-2 / H.264 Hardware decoding
Videotext Decoder
Analog audio output: stereo(L+R);
Digital audio output: S/PDIF by coaxial and optical;
S/PDIF Interface for digital bit stream out (AC-3)
YCbCr available;
1 x Scart (RGB, FBAS or S-Video);
Screen format:auto, 4:3, and 16:9;
Upgrade software through USB2.0 port;
Powerful program management function, parent lock;
1x CA slot
10/100Mbit Ethernet Interface
Directly bouquet-lists
Support WEB TV
Je retiens l'info et il faut juste que je compare tntsat à Fransat. Mais c'est vrai que c'est peut être une erreur de m'être basé sur ce kit. l'avenir me le dira.
Pour la réception des chaines indiquées, est-ce que tu reçois d17 par exemple? car ce n'est pas encore le cas ici.
" car je ne la trouve pas cette chaîne.
