Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
- DM8000HD+ :
https://mega.nz/#!9Q8TwRYL!hsBWZhpOR...z6Qh_UGCpmnw1M
- DM800HDse+ :
https://mega.nz/#!5Ys30IQR!LcYjX3X8F...YfOAsMAGUwt5pU
- DM800HD+ :
https://mega.nz/#!8d1CgDQb!E1bd3Xcpm...S9VjTzvUcbZIU4
- DM500HD+ :
https://mega.nz/#!td8XzDBK!gUWZTa-08...zd35W7EjPYibiM
Changes since previous release:
- mx3L's gstreamer revert which fixes mp4 playback from remote locations
- Spark drivers updated to 20151113
- Using aio-grab from oe-alliance which includes fixes for sprak receivers
- New Japhar IPTV List (thanks to ToySoft).
- DM8000 has no more gsod's now (thanks to ToySoft for testing!)
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
By mx3L which fixes mp4 playback from remote locations.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
- The 2.6.18 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any kernel driver from OE1.5 to 2.0.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
Gstreamer recipes (20151213):
https://mega.nz/#!ugMEjKSb!cAF-uGWX5...NxeaBxiD4FSBsI
Dreambox DM500HD:
https://mega.nz/#!qwcTUCqS!RBkQgJLwb...Eao90ArEJ0BWcs
Dreambox DM500HD V2:
https://mega.nz/#!Gp1jTDyR!Cdd-Ze2Gg...X5AmwSi-GOWXys
Dreambox DM7020HD:
https://mega.nz/#!zh8BnKgT!nmGwvubmd...Xiw28MdA3nSKjQ
Dreambox DM800:
https://mega.nz/#!GsEQHKZK!JFRw4g6qm...1vXLhIoEi2QwHo
Dreambox DM8000:
https://mega.nz/#!201GSKzb!G4cH-IQsg...iGKKuGzm86DKYQ
Dreambox DM800Se:
https://mega.nz/#!LtESQJ7a!MqXWfa3hK..._FGXg7Fn7dfFDA
Dreambox DM800Se V2:
https://mega.nz/#!X4UkyZIJ!9pI-4YR8Y...claArNPuBsdnr8
Xtrend ET10000:
https://mega.nz/#!ng03wD7L!Fd2ocVoCF...pZPlxAfW5IJxRQ
Xtrend ET9x00:
https://mega.nz/#!vhNgURKb!ZTLyCNbvR...Fv2TcMp9zMPG8M
Xtrend ET8500:
https://mega.nz/#!WkE1xRTI!aC4KPGuQ3...XolgPE27R-v4y0
Xtrend ET8000:
https://mega.nz/#!7ssUVCiY!ByEBciB0f...H-xBFC7rf52RTo
Xtrend ET7x00:
https://mega.nz/#!LpM2nA6Q!2nFv1M8-X...H70jZPQ2cT0FGU
Xtrend ET6x00:
https://mega.nz/#!HxdSgCbY!lyobqYEBg...VFhh2VZoh3uybg
Xtrend ET5x00:
https://mega.nz/#!S19gDTQL!g_woheUYu...pa88CsN5xqG2vM
Xtrend ET4x00:
https://mega.nz/#!yt9yybIT!Afg9O-59Z...ZVx7rhPWAURP7I
Formuler F3:
https://mega.nz/#!z80jHaZB!q3PNSqaqq...5kuv5clNryXoUY
Formuler F1:
https://mega.nz/#!Kps0zTjS!S3nW-oZxB...o7F5ZQ9XFvlrD0
Mut@nt HD2400:
https://mega.nz/#!z81gwIYb!8ScjiRcwR...coyiHN2TiemBF0
Mut@nt HD1200:
https://mega.nz/#!qskT3RLa!sAx7Rktst...ranynX2s_rYE4k
Mut@nt HD1100:
https://mega.nz/#!bsUzGIzS!_AKWRu_75...1BMgHspnTw4ZgM
Mut@nt HD500C:
https://mega.nz/#!b8FnlKiZ!-H83sq6ki...-dgoSkubJ4XwsU
MaxDigital XP1000:
https://mega.nz/#!X5cl1J7R!qWX6grnqq...yJgVLLKXix-fas
XSarius Fusion HD:
https://mega.nz/#!qts2yB6Q!8IOeZvFxi...eY1cPifjgZzIqI
XSarius Fusion HD Se:
https://mega.nz/#!XlMXXKQT!tPQ7XVWRo...yMB-IaetiafrII
Vu+ Solo:
https://mega.nz/#!ml9HwZCa!7e1354Px-...zbJi6A2X6zjnQ8
Vu+ Solo 2:
https://mega.nz/#!vsdBTSIB!7fP-aeY64...MJ703abGLg_CUc
Vu+ Solo Se:
https://mega.nz/#!flFVDKQC!F_1wqnmwQ...Tza_KfwKVBfZDM
Vu+ Duo:
https://mega.nz/#!20lHhLxL!1C1ipCAub...kNfk_BWxTLhQHY
Vu+ Duo 2:
https://mega.nz/#!Po1THRiD!3MqGFJSZj...yMLtM3S2Sbndo8
Vu+ Ultimo:
https://mega.nz/#!m9dz0aSA!YSdmyXZpb...madGG0VHX4ycto
Vu+ Uno:
https://mega.nz/#!S8FDiYTa!hksnPpsvR...ZfODtJKfnWwMb8
Vu+ Zero:
https://mega.nz/#!3s1iCL4B!4iHmnF_Fw...CiKpJNd0KmvAXs
Fulan Spark:
https://mega.nz/#!jpVwRBrI!D-rCx33eI...ODFzm9VCyLBSB8
Fulan Spark7162:
https://mega.nz/#!zwVHDarK!5WRRZrz38...ucfvZpNK-ursUU
AirDigital Zgemma Star S / H1 / H2 / 2S:
https://mega.nz/#!P0VQUAaR!0zyA-p5P_...o5GhmCdyd5lslg
AirDigital Zgemma Star HS / H2S / H2H:
https://mega.nz/#!XkMyEBjL!NjUUG9AuF...7rkqoEM6llV6DI
OEM:
- DM8000HD+ :
- DM800HDse+ :
- DM800HD+ :
- DM500HD+ :
Sim2 DM800Se:
https://mega.nz/#!m8kkyAjI!d-l0k8NAM...znNaNmLRcovBCU
Sim2 DM800Se V2:
https://mega.nz/#!XwUAmZ5T!RJXQZa4O5...Exjanz_9nPoSb4
Sim2 DM800:
https://mega.nz/#!ulMhkLSD!8rbKgFpr2...lV0xZH5dnc-yxc
Sim2 DM500HD:
https://mega.nz/#!nk0BHDLR!Zjaq10CDD...kjcJXJayb5yFUo
E-Star DM800Se:
https://mega.nz/#!P40RAQBR!-WmxWD_E1...fnr4lcYFzeVfaA
E-Star DM800 (untested):
https://mega.nz/#!r8NhSBYI!VdTlc7Eg6...B0qlylEp5r9XyE
