    janvier 2015
    Hello, I am a bit stuck because I can add a transponder to capture HD channels on 5W (12648 V transponder) but I have not the parameter symbol rate ... qqun can give me that info? Thanks jeans
    Rana imran
    Citation Envoyé par genafbauder Voir le message
    Hi,
    As explained above (in French) this transponder uses a professional mode of the DVB-S2 standard (ACM/VCM multistream) which is not supported by consumer receivers. The symbol rate is 29500 but this will not help wit a standard DVB-S2 receiver.
    If you want to receive this transponder which carries 9 HD channels in the clear, the only equipment which allows its reception is a USB PC peripheral tuner TBS5925 (cost approx 200€).
    http://www.amazon.fr/TBS-external-sa.../dp/B006RQW19E
    There are also many italian TV channels (RAI and Mediaset) in the clear using the same system on this 5°W position.
    http://www.lyngsat.com/Eutelsat-5-West-A.html
    janvier 2014
    TBS 5925 works fine on W7 or 8 and Linux,but doesn't work on Macs
    and I hope you're familiar with computers because the set up can be a bit awkward
