Hi,
As explained above (in French) this transponder uses a professional mode of the DVB-S2 standard (ACM/VCM multistream) which is not supported by consumer receivers. The symbol rate is 29500 but this will not help wit a standard DVB-S2 receiver.
If you want to receive this transponder which carries 9 HD channels in the clear, the only equipment which allows its reception is a USB PC peripheral tuner TBS5925 (cost approx 200€).
http://www.amazon.fr/TBS-external-sa.../dp/B006RQW19E
There are also many italian TV channels (RAI and Mediaset) in the clear using the same system on this 5°W position.
http://www.lyngsat.com/Eutelsat-5-West-A.html
