Nouvelle version du 20 Novembre 2015 avec le dernier GStreamer 1.6.2, le nec plus ultra pour feeds IPTV,
pour DM800HD/DM800HDse/DM8000HD/DM500HD
- Gstreamer (v1.6.2) has been updated to master git which carries many fixes.
- No more internet connection required during bootup.
- Feeds online for online update of image and future updates/fixes if necessary.
- IPTV List and Jam Panel are now pre-shipped.
- Japhar Addon Manager 5.2 included.
- IPTV List built-in with 750+ IPTV FREE Channels.
- Many dvbmediasink fixes.
- Many stuff I forgot :P
MEGA (Japhar) :
- DM800HD : https://mega.nz/#!5R1mzQqb!MMfq5idmK...4BswWC4eVJXWRM
- DM800HDse : https://mega.nz/#!UZ0DHQTb!yq7DdwWk_...4LQ5qKwxXWPaSg
- DM500HD : https://mega.nz/#!oBUy3BaA!J04qukJz8...fmbSZdX_lrrOno
- DM8000HD : https://mega.nz/#!gBkUiQJA!zbWLvTmu0...mlupIfSR4FR4y0
TS
- Gstreamer 1.6.x has been updated
- Newer gstreamer 1.6.x master git snapshot:
They've pretty much reworked HLS (m3u8) handling completely.
There should be no more jumps when switching bitrates.
- DTS Downmix should now be working on the dm800se, dm500hd and dm8000.
Also pausing the video should work now (untested).
- Fragmented streams work now (m3u8)
- Remote control delay is now set by default to 300ms
- Improved streaming performance in both the dvbmediasink and enigma2, Dreambox fixes for the dvbmediasink:
Framerate and resolution should now be handled correctly.
- Fragmented streams should now play more smooth and give less freezes due to async changes.
- IPTV List and JAM 5.2 Panel are now pre-shipped.
- IPTV List built-in with 800+ IPTV FREE Channels.
- DM800HD : https://mega.nz/#!1BFBHJiQ!Y3OBOTtf4...k3AQqweQwcW7RQ
- DM800HDse : https://mega.nz/#!BJcA2ZgJ!cUYHK6RCn...i4KULjojgP9GgI
- DM500HD : https://mega.nz/#!RZ1FiArQ!qO6MS-72Z...vLe_0oONMw48vI
- DM8000HD : https://mega.nz/#!EY13zT4Z!8z0HFTcis...g5wpBTsX_GPQ_s
Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
- DM8000HD+ :
https://mega.nz/#!9Q8TwRYL!hsBWZhpOR...z6Qh_UGCpmnw1M
- DM800HDse+ :
https://mega.nz/#!5Ys30IQR!LcYjX3X8F...YfOAsMAGUwt5pU
- DM800HD+ :
https://mega.nz/#!8d1CgDQb!E1bd3Xcpm...S9VjTzvUcbZIU4
- DM500HD+ :
https://mega.nz/#!td8XzDBK!gUWZTa-08...zd35W7EjPYibiM
Changes since previous release:
- mx3L's gstreamer revert which fixes mp4 playback from remote locations
- Spark drivers updated to 20151113
- Using aio-grab from oe-alliance which includes fixes for sprak receivers
- New Japhar IPTV List (thanks to ToySoft).
- DM8000 has no more gsod's now (thanks to ToySoft for testing!)
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
By mx3L which fixes mp4 playback from remote locations.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
- The 2.6.18 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any kernel driver from OE1.5 to 2.0.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
Gstreamer recipes (20151213):
https://mega.nz/#!ugMEjKSb!cAF-uGWX5...NxeaBxiD4FSBsI
Dreambox DM500HD:
https://mega.nz/#!qwcTUCqS!RBkQgJLwb...Eao90ArEJ0BWcs
Dreambox DM500HD V2:
https://mega.nz/#!Gp1jTDyR!Cdd-Ze2Gg...X5AmwSi-GOWXys
Dreambox DM7020HD:
https://mega.nz/#!zh8BnKgT!nmGwvubmd...Xiw28MdA3nSKjQ
Dreambox DM800:
https://mega.nz/#!GsEQHKZK!JFRw4g6qm...1vXLhIoEi2QwHo
Dreambox DM8000:
https://mega.nz/#!201GSKzb!G4cH-IQsg...iGKKuGzm86DKYQ
Dreambox DM800Se:
https://mega.nz/#!LtESQJ7a!MqXWfa3hK..._FGXg7Fn7dfFDA
Dreambox DM800Se V2:
https://mega.nz/#!X4UkyZIJ!9pI-4YR8Y...claArNPuBsdnr8
Xtrend ET10000:
https://mega.nz/#!ng03wD7L!Fd2ocVoCF...pZPlxAfW5IJxRQ
Xtrend ET9x00:
https://mega.nz/#!vhNgURKb!ZTLyCNbvR...Fv2TcMp9zMPG8M
Xtrend ET8500:
https://mega.nz/#!WkE1xRTI!aC4KPGuQ3...XolgPE27R-v4y0
Xtrend ET8000:
https://mega.nz/#!7ssUVCiY!ByEBciB0f...H-xBFC7rf52RTo
Xtrend ET7x00:
https://mega.nz/#!LpM2nA6Q!2nFv1M8-X...H70jZPQ2cT0FGU
Xtrend ET6x00:
https://mega.nz/#!HxdSgCbY!lyobqYEBg...VFhh2VZoh3uybg
Xtrend ET5x00:
https://mega.nz/#!S19gDTQL!g_woheUYu...pa88CsN5xqG2vM
Xtrend ET4x00:
https://mega.nz/#!yt9yybIT!Afg9O-59Z...ZVx7rhPWAURP7I
Formuler F3:
https://mega.nz/#!z80jHaZB!q3PNSqaqq...5kuv5clNryXoUY
Formuler F1:
https://mega.nz/#!Kps0zTjS!S3nW-oZxB...o7F5ZQ9XFvlrD0
Mut@nt HD2400:
https://mega.nz/#!z81gwIYb!8ScjiRcwR...coyiHN2TiemBF0
Mut@nt HD1200:
https://mega.nz/#!qskT3RLa!sAx7Rktst...ranynX2s_rYE4k
Mut@nt HD1100:
https://mega.nz/#!bsUzGIzS!_AKWRu_75...1BMgHspnTw4ZgM
Mut@nt HD500C:
https://mega.nz/#!b8FnlKiZ!-H83sq6ki...-dgoSkubJ4XwsU
MaxDigital XP1000:
https://mega.nz/#!X5cl1J7R!qWX6grnqq...yJgVLLKXix-fas
XSarius Fusion HD:
https://mega.nz/#!qts2yB6Q!8IOeZvFxi...eY1cPifjgZzIqI
XSarius Fusion HD Se:
https://mega.nz/#!XlMXXKQT!tPQ7XVWRo...yMB-IaetiafrII
Vu+ Solo:
https://mega.nz/#!ml9HwZCa!7e1354Px-...zbJi6A2X6zjnQ8
Vu+ Solo 2:
https://mega.nz/#!vsdBTSIB!7fP-aeY64...MJ703abGLg_CUc
Vu+ Solo Se:
https://mega.nz/#!flFVDKQC!F_1wqnmwQ...Tza_KfwKVBfZDM
Vu+ Duo:
https://mega.nz/#!20lHhLxL!1C1ipCAub...kNfk_BWxTLhQHY
Vu+ Duo 2:
https://mega.nz/#!Po1THRiD!3MqGFJSZj...yMLtM3S2Sbndo8
Vu+ Ultimo:
https://mega.nz/#!m9dz0aSA!YSdmyXZpb...madGG0VHX4ycto
Vu+ Uno:
https://mega.nz/#!S8FDiYTa!hksnPpsvR...ZfODtJKfnWwMb8
Vu+ Zero:
https://mega.nz/#!3s1iCL4B!4iHmnF_Fw...CiKpJNd0KmvAXs
Fulan Spark:
https://mega.nz/#!jpVwRBrI!D-rCx33eI...ODFzm9VCyLBSB8
Fulan Spark7162:
https://mega.nz/#!zwVHDarK!5WRRZrz38...ucfvZpNK-ursUU
AirDigital Zgemma Star S / H1 / H2 / 2S:
https://mega.nz/#!P0VQUAaR!0zyA-p5P_...o5GhmCdyd5lslg
AirDigital Zgemma Star HS / H2S / H2H:
https://mega.nz/#!XkMyEBjL!NjUUG9AuF...7rkqoEM6llV6DI
OEM:
- DM8000HD+ :
- DM800HDse+ :
- DM800HD+ :
- DM500HD+ :
Sim2 DM800Se:
https://mega.nz/#!m8kkyAjI!d-l0k8NAM...znNaNmLRcovBCU
Sim2 DM800Se V2:
https://mega.nz/#!XwUAmZ5T!RJXQZa4O5...Exjanz_9nPoSb4
Sim2 DM800:
https://mega.nz/#!ulMhkLSD!8rbKgFpr2...lV0xZH5dnc-yxc
Sim2 DM500HD:
https://mega.nz/#!nk0BHDLR!Zjaq10CDD...kjcJXJayb5yFUo
E-Star DM800Se:
https://mega.nz/#!P40RAQBR!-WmxWD_E1...fnr4lcYFzeVfaA
E-Star DM800 (untested):
https://mega.nz/#!r8NhSBYI!VdTlc7Eg6...B0qlylEp5r9XyE
Changes :
- Gstreamer 1.7.1
The mp4 playback from remote urls has been fixed upstream so no more revert for that.
libsoup http-handler has been updated so also no revert for that as well
- New libsoup handler for http urls
- New winter logo
- More free space laugh
Ive added a dirty hack that will upx compress the binary before package_write_ipk
We now have 2 to 3MB more free space (very nice, great success)
- New xvid/divx5 bitstream unpacker by mx3L, this should fix avi files with wrong fourcc
- The usual batch of dvbmediasink fixes by christophecvr and mx3L
- Wifi drivers have been refactored a bit, I dont auto-load the rt7777 anymore.
it should kick in when you plugin your wifi stick.
If not then Ill create a ppanel which will allow you to choose which driver you want to use: rt3070, rt55xx or rt7777 (since they cant be loaded at the same time)
by MastaG
DM8000HD: https://mega.nz/#!YRklVADa!jfV_0mM-6...zLFubOFmA7VCAg
DM800HDse : https://mega.nz/#!BAtCwQ4R!r15VnQlfK...nDNfLsp9CQBYbU
DM800HD : https://mega.nz/#!kYlVHRoD!pWuty-xvl...6iGabO8Dk77bno
DM500HD : https://mega.nz/#!VMcAyQwC!Z4CxifG_3...GSS8MW90MLYBkc
Feel free to post images on all your satellite forums you like and share with all your friends these excellent tools and new images with full IPTV support, the best around, even better than on original boxes !!! Thank you !
Nouvelle version v14 avec IPTV de dernière génération, avec dernier GStreamer 1.8 et plus de 1200 chaines TV du monde entier, dans toutes les langues, du Brésil, des USA à la Chine, en passant par la France, l'Allemagne, l'Arabie Saoudite, Dubai, le Maroc, etc. Tout ceci gratuit et chaines gratuites par IPTV. Et de nombreuses WebCam, de Copacabana / Plage de Rio, Hawaii, Las Vegas, Los Angeles, Miami, New York, etc etc... comme la Tour Eiffel !
Bon amusement.
DM800HD v14 :
https://mega.nz/#!5ENX1AII!s6KMlwI4f...iuObJWv5T47Xmc
DM800HDse v14 :
https://mega.nz/#!gdkjADIC!DFC9al1GD...zc6jDaTzvD_Uk8
DM500HD v14 :
https://mega.nz/#!4MkRlYhZ!M5rLZhMMV...XmNcthcq8WsSmE
DM8000HD v14 :
https://mega.nz/#!FV0RTSwR!VT9m2Jme8...YyMKioN5hIy__Y
Changes since last release:
- gstreamer upgraded to 1.7.90 (nearing the final 1.8 release)
- ffmpeg updated to 3.0
- gstreamer1.0-libav is now build against ffmpeg (thx to Taapat).
- a patch from mx3L for servicemp3 that should speed up IPTV zapping
- a second patch from mv3L for servicemp3 that should fix a possible GSOD when switching audio tracks
- a third patch from mx3L for the dvbmediasink that should fix a possible GSOD on seeking in mp4 streams
- support for bluray isos by Taapat
- remote controls should now have their media-button working
- added X Solo Mini 3 build
- New vermagic magics, you should be able to load any kernelmodule again.
- patch by christophecvr for setting the debug level in Menu -> Settings -> User-interface settings.
Note :
The patch for setting the debug level is very important since it fixes many possible IPTV issues on slower receivers like the DM800.
Its highly recommended to set it level 0 :)
- MEGA DM8000HD+ Japhar SSL84J :
https://mega.nz/#!dENQEIpT!Kj1EyB_VM...ozoxsHnm4tjoNE
- MEGA DM800HDse+ Japhar SSL84J :
https://mega.nz/#!FRMRAAhA!UVp28MxKH...u0KvEFNbgNMqRg
- MEGA DM800HD+ Japhar SSL84J :
https://mega.nz/#!FZVQnTJT!BoUyk-oVu...ZBnqT5w-TFFIZE
- MEGA DM500HD+ Japhar SSL84J :
https://mega.nz/#!BFMkkS7S!g9BZUfwBY...3vPuBljxXwnM0s
OpenPLi 4.0 IPTV GStreamer 1.8.0 by MastaG (v16)
http://www.ourdreambox.com/gallery/74/full/3016.jpg
Changes:
- Gstreamer 1.8.0 stable release
- New PLi spring logo
- Upgrade OpenVPN to 2.3.8
- Upgrade OpenSSH to 7.1p2
- Upgrade OpenSSL to 1.0.2g
- Patched and bumped Python due to OpenSSL not supporting SSLv3 anymore
- Upgrade Japhar-IPTV list to 1.6
- Upgrade rtmpdump from oe-alliance and let it provide librtmp as well
- Upgrade ffmpeg to 3.0.1
- Patch for dvbmediasink from mx3L for writing PTS on every PES header
This could possible fix some m3u8 streams freezing
- Removed the patch for dvbmediasink which should fix seeking in some mp4 streams
Since I couldn't reproduce the problem
- Rewrote Dreambox kernel recipes which should fix certain models not booting
- Fixed CrossEPG
- Fixed very large Packages.gz on the server
- Merged latest openpli-oe-core changes
- Merged latest OpenPLi enigma2 changes
- Upgrade oscam to rev 11225 and applied joeuser's latest tryfix oscam-emu patch
Emulating PowerVU should now work for multiple pids
- Lots of stuff I forgot...
DM800HD+ : https://mega.nz/#!sU13mAxI!J0Av9B6D7...v3cMRAsDyANDWY
DM500HD+ : https://mega.nz/#!NR0hHKhT!fX5cI-pgR...kxX59yZW9wVG4o
DM800HDse+ : https://mega.nz/#!MENwRaDb!AsZrkisSZ...xNqWFWFnzz0gLA
DM8000HD+ : https://mega.nz/#!cZcWyBzL!wQiPAfzzL...9Togml5GgiOM54
OpenPli 4.0 IPTV by MastaG / Japhar Team with 1200 FREE IPTV Channels and with GStreamer 1.9.0.1 (April 15th 2016)
Changes:
- New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
- Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
- gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
Login with telnet and issue: opkg update && opkg install ffmpeg
- Latest openpli-oe-core changes
- Latest enigma2 changes
- spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
Note: servicemp3 still uses gstreamer
- spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
The servicemp3 memleak patch has been applied with some other patches/commits I found useful
- spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
- Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
DM8000HD+ : https://mega.nz/#!NtRDVY4S!lghmCsrxJ...3mGLiVRvMs3G28
DM500HD+ : https://mega.nz/#!ZwB3wTqI!JjyTk2sAe...TSerbJrtZW8BxY
DM800HDse+ : https://mega.nz/#!AwhlABgI!47Lh28i8H...iTBmgGQhBiK3jU
DM800HD+ MEGA Japhar : https://mega.nz/#!hBU3xQiR!G6FE1PdpG...ufhENAJkwlo9Tw
DM800HD+ DataFileHost Japhar : https://www.datafilehost.com/d/3325c880
VU+ Solo Ferrari V3 : https://mega.nz/#!Y4RTFQpI!_v8UbqT50...iJGO3kU90JXjFY
VU+ Duo Ferrari V3 : https://mega.nz/#!ppxzjKpB!_dwrPoGnz...DHE3A1JkNpTuFo
VU+ Uno Ferrari V3 : https://mega.nz/#!IoY2lT7A!5Q-d7vKs4...hiV5TcQrdIUuLA
VU+ Solo2 Lonrisun V1 : https://mega.nz/#!49onCbrL!eq0nVAJLM...7xkrwfK4OadW3Y
VU+ Solo2 Lonrisun V4(1) : https://mega.nz/#!txIyjJwT!Y_zaBha5V...6VA90fAUlVihog
VU+ Solo2 Lonrisun V1(2) : https://mega.nz/#!4og1FKaI!Ecbp1Fz57...0_19olCzRj2blU
OpenPli 4.0 IPTV by MastaG / Japhar Team with 1300 FREE IPTV Channels and with GStreamer 1.9.0.1b (May 6th 2016)
Changes:
- Latest gstreamer 1.9.0.1 snapshot based on recipes from christophecvr:
* Proper fix for HLS segfault on stop
* Re-enable the rtmp seeking and potential segfault fix
* gstreamer1.0-libav is now built against system ffmpeg instead (this differs from chris recipes) *
* dvbmediasink patches for Vu Solo 4K, hd1265 and hd1500 from oe-alliance
- FFMpeg updated to 3.0.2 and is now installed by default *
- Backports to enigma2 for sh4 (mainly servicemp3.cpp related)
- Fix EPG on sh4 receivers
- exteplayer3 is now installed by default, thank you mx3L and samsamsam *
- gstplayer is now installed by default, thank you mx3L and samsamsam
- Mediatomb is now in the feeds
- MediaPlayer2 is now installed by default, thank you mx3L
- SubsSupport (for MediaPlayer2) is now installed by default, thank you mx3L
- No more russian tuxtxt
- Its now possible to set the debug level again in the UI-settings menu, thank you christophecvr
- Latest enigma2 changes, thank you OpenPLi
- latest openpli-oe-core changes, thank you OpenPLi
- ServiceApp, thank you mx3L !!!
Known issues:
- On spark7162 (and 7111 probably as well) fragmented streams such as hls (m3u8) will skip and freeze a lot.
This happened sometime after the official Gstreamer 1.8.0 release and I didnt found the cause yet.
It is not related to the dvbmediasink since it doesnt happen on mips receivers and the code in the dvbmediasink didnt change.
Configure your streams to play with exteplayer3 instead, read below.
- * On the 64MB Dreambox models (DM800HD, DM800Se and DM500HD) there is not enough space to ship ffmpeg.
This means that exteplayer3 and gstreamer1.0-libav arent installed as well because they depend on ffmpeg.
See my attached guide to copy over the root filesystem to a storage device.
- Some Dreambox remotes may behave very sensitive.
Thanks for the hard work from mx3L and samsamsam you can now play your IPTV streams with exteplayer3 or gstplayer instead of the default dvbmediasink.
Especially using exteplayer3 will give much better performance on playing HLS streams compared to gstreamer + dvbmediasink.
For example, playing DJING underground 720p never worked very well on my DM800HD and now it does
DM800HD+ Japhar : https://mega.nz/#!5B81hYqB!x-XZaEfEW...O2zXuFWsGMcBbA
DM500HD+ Japhar : https://mega.nz/#!9JtGwAAb!ePV-MQPr9...2PM2HgB-9gjxhI
DM800HDse+ Japhar : https://mega.nz/#!UcMSASTA!U-dRlAtTX...D2-q1Nzp0XeawA
DM8000HD+ Japhar : https://mega.nz/#!oFEAxaCa!y2YvAL-40...kQ8VNfKUuiHW88
VU+ Solo Ferrari V3 : https://mega.nz/#!whgxgRrQ!FPma5g5i2...3aEJZxVVa8UgJk
VU+ Duo Ferrari V3 : https://mega.nz/#!1hYGBaqQ!Sllvhn_3y...F5xz4KhCPDOhlY
VU+ Uno Ferrari V3 : https://mega.nz/#!s8BERJDJ!GuBIDo0p0...FoYIGgOxzhcx7k
VU+ Solo2 Lonrisun V1 : https://mega.nz/#!glwmDQDT!FtMbec3kb...bn1VsZ0lzF0HF4
VU+ Solo2 Lonrisun V4.2 : https://mega.nz/#!A9xkwQ4Z!vytca1lhn...xYu92rvNGW6kTU
VU+/DM Japhar OpenPLi 4.0 IPTV image from MastaG, 1300 Free IPTV Channels
Here s a new batch of images based on OpenPLi 4 with many contributions from various openpli.org forum members and some bits taken from oe-alliance.
So this is basically a tribute to them
It took me a while since I was very short on time and I had to re-install my build-rig, move to a new feed-server etc...
SO DUE TO A NEW FEED-SERVER ONLINE UPDATE FROM PREVIOUS IMAGES IS NOT POSSIBLE!
DON T TRY TO CHANGE THE URL IN THESE OLD IMAGES SINCE THERE S BEEN TOO MANY CHANGES WHICH WILL BREAK THINGS!
PLEASE FLASH A CLEAN IMAGE INSTEAD!
So here s whats up:
- Brand new bootlogo thanks to .:MarcinO:.
- OpenPLi enigma2 rev: 4bf2f1e45593065f9e2b4563f30463487b727c94
- OpenPLi oe-core rev: d76cfe6a39c6613ac77578840b214f0f1e748a39
- Taapat s Fulan enigma2 rev: 2a984c500f5b2ea657f68742b7dc4e47f5586483
- New receivers supported:
* osmini
* osminiplus
* spycat
* spycatmini
* et7000mini
* xpeed lx
* xpeed lx pro
- New feed server located in Europe thanks to the Japhar team!
- New Japhar IPTV list
- No more use of UPX compression on ARM platform (should fix the Vu+ Solo 4K build)
- Latest gstreamer 1.9 revision from master branch
- FFmpeg 3.0.2 with extra options enabled (based on oe-e recipe)
- Kodi 16.1 for Vu+ Solo 2, Solo Se, Duo 2, and Solo 4K (thanks to mx3L for his bsp + recipes)
- More wifi drivers (mt7601, rt7777 etc..) taken from oe-alliance
- Slightly newer v4l modules for kernel 2.6.18 (dm800)
- New version of mx3L s serviceapp now supports EPG and embedded subtitles
- New version of exteplayer3
- Flash extender PPanel for dm800, dm800se and dm500hd (* Please read below)
- Many other changes I forgot to mention...
Known issues:
This happened sometime after the official Gstreamer 1.8.0 release and I didn t found the cause yet.
It is not related to the dvbmediasink since it doesn t happen on mips receivers and the code in the dvbmediasink didn t change.
Flash extender for DM800, DM800Se and DM500HD:
Since these receiver only feature 64MB of internal flash space, I ve been unable to ship all packages.
ffmpeg, exteplayer3, gst1.0-libav, mediaplayer2, iptv player, subssupport etc.. are missing due to insufficient space.
That s why I ve created a simple PPanel script for moving the entire internal flash to an external storage device such as internal hdd or usb disk.
The PPanel will also install all the missing packages for you.
So you can have all the bells and whistles like the other receivers
However please note that:
- It will format your storage device thus deleting everything.
- It s not compatible with other flash-extenders such as barry alen, multiboot etc...
- You ll need a working internet connection when running the PPanel or else it cannot install the missing packages.
- You need to patient! As the script runs you ll only see a black screen which an take up to 15 minutes depending on the size/speed of your storage device and your internet connection.
You can find it under Blue Panel -> PPanels
ServiceApp and exteplayer3:
For example, playing DJING underground 720p never worked very well on my DM800HD and now it does :)
In a nutshell here s how it works.
In your /etc/enigma2/ directory you have your channel bouquets with the .tv and .radio extensions.
Inside these files there s this for example:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)
#DESCRIPTION DJING Underground (CDN)
By default this will play with the gstreamer dvbmediasink (which is currently broken for sh4).
If you like to play your stream with exteplayer3 instead you should change the 4097 to 5002, like this:
#SERVICE 5002:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)
You can also change it to play with gstplayer using 5001:
#SERVICE 5001:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)
So it s like this:
4097 = default player, which is the dvbmediasink if serviceapp is not enabled
5001 = gstplayer
5002 = exteplayer3
Now let s say you d like to convert your entire bouquet to play with exteplayer3, simply login to your receiver with telnet/ssh (use PuTTY for Windows).
And issue to the following commands:
First stop enigma2:
init 4
Then change your bouquet to make all streams play with exteplayer3, lets say userbouquet.favourites.tv:
cd /etc/enigma2
sed -i s/^#SERVICE 4097/#SERVICE 5002/g userbouquet.favourites.tv
Then restart enigma2:
init 3
That s it !
You can also make exteplayer3 the default backend for playing back everything.
Go to Menu -> Plugins -> ServiceApp and set exteplayer3 as default.
Keep in mind that with exteplayer3 or gstplayer as default backend you will not have support for external subtitles yet (.srt for example).
That s why I ve added MediaPlayer2 and SubsSupport from mx3L.
Please thank mx3L for the hard work he put into this
- Japhar
DM500HD+ : https://mega.nz/#!3VBXEDhR!xrobDWOeM...fB2TcAtv3v6pYA
DM800HD+ : https://mega.nz/#!nVhQnZYZ!H56CtR356...JemhCY96V53JME
DM800HDse+ : https://mega.nz/#!nVQFSKbL!ZebU1ZuME...gr295oOS7u9OnM
DM8000HD : https://mega.nz/#!eFhUmJYZ!SuirJs7XP...PC4zc8s_eGNfLE
