un petit tour du coté des balises aéronautiques
https://www.flightsim-corner.com/all...-aeronautique/
petit aperçu:
https://www.flightsim-corner.com/wp-...loads/VOR1.jpg
petit aperçu:
Un petit tour par le Limousin
Un ancien parle de sa vie de faite entre autre de radio et d'ondes.
https://france3-regions.francetvinfo...d-1631020.html
Petit article et vidéo sympa
Merci France 3 Limousin:top:
http://www.wrightsaerials.tv/aerialp...images/080.jpgCitation:
This is a cunningly and cheekily installed Labgear ten element aerial, the fixing contrived to get it into a position where it could see Sandy Heath between the buildings of Cambridge. For some reason the aerial has been clamped at a point along the boom rather than behind the reflector. As supplied these aerials had a plastic insert that allowed a conventional 1” clamp to hold a 12mm square section boom. Because the 12mm boom wasn’t very strong, if an Antiference No 1 clamp was used the claws would deform the boom enough to weaken it, and it would eventually snap. That’s what’s happened here. I suppose the installer needed the swivel and tilt clamp supplied with the aerial for the bottom end of the mast, so he improvised at the top end. Since the reflector and dipole have remained in place, I guess the viewer was unaware of the disaster. Probably it was some fusty old prof who didn’t watch much telly anyway.
Alors là ! :) :) :)
Les antennes de Cricri sont écrasées ! :cool:
Une fois montées, mais voir le détail ensuite.
http://www.radioamateurs.news.scienc...ntenne-Mat.jpg
http://www.radioamateurs.news.scienc...LA8YB_rail.jpg
Impressionnant !
:top:
bonsoir a tous.
pour les bricoleurs.
https://www.instructables.com/id/A-F...ed-In-My-Yard/
https://nsa40.casimages.com/img/2019...2827140443.png
petit mais cos... utile
https://forum.telesatellite.com/atta...87&cid=1&stc=1
Cette petite parabole m'a permis de passer d'une connexion adsl de 2mb/s, généreusement fournie par l'agrume nationale, sur une ligne cuivre de 5km à une connexion par faisceau hertzien dirigé de 8km et 30-40 mb/s. symétrique.
C'est un fai associatif qui permet cet exploit. Une fibre pro mutualisée sur un peu plus de 500 adhérents. Moins cher et plus véloce.
Petite vidéo à voir ici (twitter/ANFR)
https://twitter.com/anfr/status/1108...154657796?s=19
